It might just be that I am being extremely thick, but I heave searched my ULEAD Media Studio 6 manuals thoroughly, and also searched this and other www sites. How do I do it?
Thanks,
David.
Load the avi into TMPG as video source. Go to setting > advanced > source range. Select the frame you want as start and end frame. Back to the main window, select file > outout to file > Sequence BMP/..../JPG. Save as .jpg.
Download the PowerPlayer and click on the snapshot (button with the shape of a camera). The BMP file will go to the directory you set in the Config tool(button looks like a hammer):
http://www.cyberlink.com.tw/english/download/trial/vpp.asp
Convert the BMP to JPEG using some graphics software... Hope this helps.
If you are willing to pay, try Adobe Premiere which in my opinion is way overkilling...
In Virtual Dub:
Load the AVI file, (if ___x480, then apply the 'Telecide' filter), frame advance to the frame you want to capture, then 'Video| Copy Output frame to clipboard'.
Load Paint Shop Pro (or your favorite paint package) and hit 'Edit|Paste as new image'. Then save it as png, jpg, bmp, whatever you want.
extract a matrice from an xvid avi file ? [SOLVED]
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 15th Nov 2011, 10:14 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 19:57 -
Extract the second soundtrack from avi file
By SB4 in forum AudioReplies: 4Last Post: 4th Mar 2010, 12:44 -
How to extract video from ots file ?
By JN in forum Video ConversionReplies: 2Last Post: 14th Feb 2009, 01:21 -
How to extract an AVI clip from a ts video file?
By alegator in forum Video ConversionReplies: 5Last Post: 10th Mar 2008, 20:48
